I was EOR for a large industrial warehouse somewhere in America. The structure is to be a metal building (designed by a qualified metal building manufacturer). Basically, then, I only designed the foundation.
There are several jib cranes scattered throughout the building. Believing it to be more efficient to use column-mounted jibs, we decided to go that route. We arranged the column grid so that the jibs would coincide with building columns, and designed the footings accordingly. We then made sure the jib reactions were conveyed to the metal building engineer.
As part of a long list of "cost-cutting" items (I could rant for hours about the negotiations between owner and contractor, without A/E input), the GC changed these jibs to free-standing jib cranes. Our resulting directive was that the footings would be designed by the crane manufacturer, and we wouldn't have to worry about it. Sounds great--less I have to worry about. Except, of course, that now my column footings will interfere with someone else's crane footings.
And now I have begun seeing these crane submittals come through, with footings designed, but there is no seal on the drawings. I also looked the crane company up on the state's website, and they are not authorized to practice engineering.
The first question, I suppose, is does the footing for a single crane (at multiple locations) require an engineer's seal? I say yes, and I'm about to notify the GC that he has to submit sealed drawings for these footings. Further, I'm also going to require the CA number for the firm that designs the footings. This will likely end up with me having to design the footings after all.
The next question is: Should I report the crane supplier to the Board for "practicing or offering to practice engineering..." without a license or certificate of authorization?
