Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
JLNJ said:2006 IBC Section 101.2
"The provisions of this code shall apply to the construction, alteration, movement, enlargement, replacement, repair, equipment, use and occupancy, location, maintenance, removal and demolition of every building or structure or any appurtenances connected or attached to such buildings or structures."
Typically this question arises with non-structural requirements that are in the IBC. Such as, the IBC essentially requires that all (non-residential) stairs have a max rise of 7" and a min run of 11", OSHA allows up to a 10" rise and a 10" run. In industrial facilities, this can be a huge difference in the cost and size of a structure as it takes a much larger footprint to fit the "IBC compliant" stairs (typically, its the footprint that is the issue). I don't see wanting to follow OSHA requirements but not IBC requirements as a lack of ethics in this case.EDub24 said:With that said we always design to the IBC and the relevant codes. I can't imagine why someone wouldn't do that even if it's allowed unless they are seriously lacking in the ethics department...
That's fine from a strictly structural (strength) perspective, but the IBC has so many other requirements in it that simply don't fit with many industrial type structures. The stair example above being one, energy efficiency requirements being another.IBC 2015 said:101.2 Scope. The provisions of this code shall apply to
the construction, alteration, relocation, enlargement, replacement,
