weavedreamer
Automotive
In the notes of a print:
MAXIMUM PARTING LINE PERMISSIBLE:
THICKNESS: 0.18
EXTENSION: 0.10
DIMENSIONING AND TOLERANCING IN ACCORDANCE WITH ASME Y14.5M-1994
On the field of the drawing is Ø40.4 ±0.1
If the part is produced to Ø40.5, how much flash extension is permissible? or what would the diameter measure across the parting line - suggesting the parting line lies on the Ø40.4 surface.
1.4(d), (e), & (f)
Is the dimension (0.10) subject to more than one interpretation?
Is specifying parting line equivalent to specifying drill or tap?
Should the thickness and extension also be highlighted as NON-MANDATORY (MFG DATA)?
THICKNESS: 0.18
EXTENSION: 0.10
1.4(d), (e), & (f)
