You can make a 3 dimensional object from an arc. If you create an arc, select it then click "Curves->Trace from Curve..." you will get a dialog box which asks for two parameters, thickness and width. Width is in the same plane as the curve and thickness is extruded perpendicular to the surface on which the curve lies.
