Arc Dimensioning in inches
  • Thread starter Thread starter Bendek
  • Start date Start date
B
Bendek
Guest
I have problem while dimensioning a arc from a whole circle (Example: I want to dimension a 60 degree area of a whole circle) and I want the measurements in inches. Is there a way to dimension so that this is shown in inches instead of degrees.
Any suggestions would be helpful.
Hi Bendek,
You have to set your dim format to inches, then you have to use Arc Length in Dim pulldown.
Hope this helps
