Jul 17, 2007 #1 A Alban Guest Hi, Which tool is used to edit the text in an arc dimension? Thanks in advance.
Jul 31, 2007 Thread starter #2 R Ricky Guest Hi, Use DDEDIT to edit the text in arc length dimensions or you can also use Properties - select the dim > Rt. click > Properties or double-click the dim - to change text overrides, alt units, prefix/suffix, etc. just like all other dimensions.
