Thanks megaladon for the reply, but the last topic that is on that thread, "Dimensioning Arcs in Drawing" doesn't work in Wildfire. Either that or I'm doing something wrong.
you can get it by make line optioin, select 2 point line and select one end point, select center point of arc (it will highlight when ur cursor go around arc or near center)while press ctrl, then release ctrl and pick another set of points and MMB click at apropriate location.
You have to select two end points of the arc first and then select the arc again and press middle button to place the dimension. Then Pro/E will ask if you want to place arc length or angular dim.
