I have created a simple one-element model in ANSYS classic to compare to some theoretical results I have calculated. I have tried creating the same model in ANSYS Workbench, but I am having trouble getting the thermal gradient to work.
The model I am working with has 40 composite layers of the same material at various orientations. I have applied mechanical loading to the edges of the single shell element and a thermal gradient (delta_t) of 700 degrees Fahrenheit. I would think that you just have to set the reference temperature to 0 degrees and add a constant temperature of 700 degrees to the element. I am just not sure how to do this in Workbench.
Please let me know if you can help me model the thermal gradient in Workbench.
Thanks!
Thanks!
