modeltech
- Aug 12, 2010
- 4
Hello all,
I am creating a transient simulation of a rotating pipe that will have a heat flux applied to its inner surface. I figured out how to do the heat flux but I can't figure out how to apply rotation to the pipe. I tried using SOLID226 (because it is a coupled field element) and created a cylinder extruded along the x-axis, meshed it, and then used:
OMEGA,10,,,,
to apply the rotational velocity about the x-axis. The result was the pipe moving in the negative y-direction.
Any help or a link to an example is greatly appreciated.
OMEGA,10,,,,
