Please see the following. It was taken from a RetainPro newsletter.
Also, see IBC 1613 below. If the wall is used for site grading, it is non-structural and not attached to any building structure.
Seismic kh factor, again
This was discussed in an earlier newsletter, but here is an update: IBC '06 requires retaining walls to be designed for seismic forces if Seismic Design Category D, E, or F applies (see Table 1613.5.6-1), and if SDS accelerations are 0.50g or greater. This is in Section 1802.2.7, which states that unless a site-specific report is provided by a geotechnical engineer, the value of kh (design acceleration) should be a ground acceleration equal to SDS / 2.5. This is further clarified in the NEHRP (FEMA) Handbook, 2003, Part 2, Commentary, Section 7.5.1. Retain Pro uses the Modified Mononobe-Okabe equation (modified Coulomb) to calculate seismic forces for cantilevered retaining walls, wherein the theta (?) factor used in the equation is tan-1 kh.. As those of you in high-risk seismic area have discovered, this added seismic force can nearly double the static force and triple the overturning moment, particularly if backfill is sloped. In our opinion this is an overly severe requirement due to the rare instances of seismic problems with retaining walls (waterfront structures subject to liquefaction excepted) and code requirements should be reevaluated. We will report more on this in our Fall newsletter. In the meantime, anyone with an opinion please email us -- we'd like your views and comments on this important issue.
IBC '06 1613 Earthquake Loads
1613.1 Scope
“Every structure, and portion thereof, including nonstructural components that are permanently attached to structures and their supports at attachments, shall be designed and constructed in accordance with ASCE 7, excluding Chapter 14 and Appendix 11A. The seismic design category for a structure is permitted to be determined in accordance with Section 1613 or ASCE 7.
Any thoughts or interpretations greatly appreciated.
