Application/mechanica
  • Thread starter Thread starter frezman
  • Start date Start date
F
frezman
Guest
I have problem with integrated mechanica i can't perfom analysis.When i start application FEA mode is check awlays is this the problem?I think i define the model give him loads,constrains,material next i start analyses and point loads and constrains and thats it
next is dead end to me.Or maybe is the problem is in instal please tell me i will need very soon to perform analyses for my project in university and want to make them in pro/e.
Don't boder the problem is sovled i write to in other forum and we solve the problem.
Hello Frezman,
Which other forum you tried to solve the problem. I have Pro - mechanica motion problem and I am not able to get help to resolve the issue.
I cannot run the analysis. I need to configure variable MM_C_HOME to read the C++ complilor . can you help me out.
thanks
Dave09,
http://www.coreshutdown.com/proe/install.htm
Scroll to bottom of page it tells you how to set the environment vairable there.
Tobyk
PS Welcome to the forum- no need to multiple post- these forums are very active.
Hello Tobyk,
Thank you very much for the reply.
sorry for the multiple posting . going crazy with this stuff. bought book also from SDC publication and know I can not run the analysis(first chapter). sorry again.
I set the variable as per the procedure. and still I get the same error.
I don't have VC98 compilor . I have Microsoft visual studio 8, do you know if it is compatible to pro-mechanica wildfire-2
Please let me know. I think VC98 is older version.
Thanks for your help.
