Hi everyone.
We are designing a ball valve in according to API6D 24th edition.
As regards the calculation notes relating to the drive train, in accordance with par. 5.20 of API6D, I would need to clarify how to check the dowels between the body/bonnet and bonnet/operator plate, in particular:
1) are the dowels considered part of the drive train? In this case they must be verified with the design torque (at least two times the breakaway torque) and with the allowables stresses indicated in par. 5.20.2?
2) the maximum allowable torque of the dowels should be higher or lower than the MAST of the stem?
Thanks for your help!
