George Logans
Chemical
- Oct 12, 2017
- 2
Hi all,
I am a chemical engineer working in the natural gas pipeline industry. It often comes up that we will use API RP 1102 as a guideline to check cyclic stress for potential fatigue in welds underneath a highway crossing.
In calculating the cyclic stresses aka the longitudinal stress due to live load, API 1102 recommends maximum applied design surface pressures of 69.4 lbs/in2 and 83.3 lbs/in2 for single and tandem axle loadings, respectively.
To calculate these two surface pressures, API 1102 takes the contact area over which the wheel load is applied to be 0.093 m2.
Would anyone be able to advise where this 0.09 m2 comes from or how it is derived? I am designing a pipeline for a haul road crossing where it will be used primarily by heavy vehicles such as dump trucks. I would suspect that the equivalent contact areas for such vehicles would not be as small as 0.09 m2.
Thank you,
George
Thank you,
George
