API - How to Apply Method to Active Document 1
Beggar
715
I'm in the very beginning stages of learning the SWX API and I have a simple question.
In the following statement (cut from API Help), how do I have the method apply to whatever document is active rather than having to specifically name the file?
Code:
swApp.GetConfigurationCount("C:\calls5\part3.sldprt")
There is a preceding statement
Code:
Set Model = swApp.ActiveDoc
but I don't understand how to use that object to meet my need.
Thanks in advance.
Bring back the HP-15
its something similar to this:
swApp.GetConfigurationCount(swApp.ActiveDoc.GetPath())
im not sure if the call is getpath(), or filename()...or something....but you get the picture
sorry, the actual call is GetPathName()
try this:
swApp.GetConfigurationCounts(swApp.ActiveDoc.GetPathName())
There are two GetConfigurationCounts methods, one for ModelDoc2 object and one for SldWorks object.
retval = ModelDoc2.GetConfigurationCount( ) only works for loaded or open SW files.
count = SldWorks.GetConfigurationCount ( filePathName ) works on files that are not opened.
If your file is already loaded or open, I think you should go with ModelDoc2.GetConfigurationCount.
[bat]Due to illness, the part of The Tick will be played by... The Tick.[bat]
