Rizkyffq
- Jun 5, 2017
- 53
Hello all,
I have read API 6A 21st edition, and i found a little problem with this standard.
In Annex F for API 6A 21st edition, validation test procedure for PR1 already removed while in API 6A 20th edition PR1 still exist.
The problem is when we have validation test of PR1 using Annex F that still using 20th edition and after that API raised their 6A to 21st edition and removed PR1 in their Annex F, and then is our validation test that already referred to the 20th edition still valid or not ?
I mean, as i know if the standard already raised the edition so the previous one is obviously cannot to be used again right ?
Despite in 21st edition there is a statement about this issue:
But as statement above, clearly it states only for "PR2" not PR1,so is it meaning that PR1 is not be accepted as valid test anymore ? or is there any alternatives to make our PR1 test that we have done becomes accordance with Annex F 21st Edition ?
Hopefully someone that expertise on API 6A may give me little enlightenment on this issue.
Thanks in advance
Thanks in advance
