Meck91
- Aug 26, 2009
- 33
Reference API 660 data Sheet:
Is heat transfer rate REQUIED is or can be same as heat transfer rate (SERVICE)?
Just want to confirm that Heat Transfer rate (Required) is what process usually specifies for the intended service of exchanger, and is basically the requirement from Process. In response exchanger manufacturer provide information on Heat Transfer Rate (Service), means that the exchanger they will manufacturer will transfer this much heat. If manufacturer is quoting off-the-shelf type of exchanger then the heat transfer rate required can be different than the heat transfer rate service.
However, if the supplier is providing a custom built exchanger than heat transfer rate (Service) must be at least equal to or slightly higher than the heat transfer rate (Required0).
Please comment on my interpretation of these two valves.
Thanks in advance.
Meck91.
Thanks in advance.
Meck91.
