alohapoint
Petroleum
- Oct 2, 2009
- 2
Hi all,
When installing a repad with a 1/4" threaded telltale per API 650, sections 3.7.5.1, and 3.7.6.1 state the tell tale hole "shall be open to atmosphere". In practice, threaded plugs are inserted with the logic that: a plug keeps moisture & rain out to avoid corrosion, prevents clogging with mud & moss, and they can be removed and checked periodically.
Why does API recommend "open to atmosphere"? What benefits make it better than using a plug?
Thanks!
Thanks!
