A tank 55 foot diameter, 48 foot tall needs to be designed per API 650. It is a waste water tank. It will have floating roof and a conical shaped bottom so that water can be drained without solid accumulating. I have a few question about this:
1. Can the plate material be SA 283C or does it need to be SA 516 70N? Can the roof material be Aluminum? Can it be SA 36?
2. If tank has conical bottom, does it need a foundation in conical shape or will it be supported on a ring?
3. If tank is drained through say a 3" outlet at the bottom of cone, is there any clogging risk? will it be a problem if the pipe that is used to drain cloggs? Plan is to have the tank drain on its own under static head without any pumps.
4. Any interior lining required?
4. Corrosion allowance same on the plate and bottom or different on two? I would guess we need more corrosion allowance on the bottom.
Does API 650 give any standard data sheet that we can just fill out to get the final data sheet? or we have to make a new datasheet?
