Good Morning Everyone,
I'm checking some pipe supports on an API 650 tank and they are all knee braces (some supporting two pipes so moments can be present). Since the shell plate deflects under loading, I'm inclined to consider it a pinned connection (despite the fully welded connection). However, adding structural and/or repads (to distribute the load into a larger portion of the shell to lower my shell stress) will stiffen the shell. Now, it still wouldn't be a fixed connection, however if I do check it as a fixed connection, I find the moment loading into the shell causes my shell stress to be too high with my current details at a couple locations.
So, when attaching structural to the shell, do you typically treat it as a fixed or pinned connection? I feel like I should go with some sort of semirigid connection and perhaps use a portion of the moment from the fixed connection, but I've never done that kind of design and wouldn't know where to begin.
And, just out of curiousity, if they were cantilevered supports, would you change your decision?
Let me know what you think, cheers,
THef
THef
