Hi Everyone, I don't usually post in these forums as I dont get to much involved in API work but recently I embarked on a project to correct a defective installation on an oil storage tank. I was hoping you guys could answer a few questions for me about how to properly design and install the spiral staircase for a tank.
- In regards to the spacing of the steps, I am looking at the requirements on figure 5-18 and 5-19 that have all the guidelines for staircase design. The question is, are there any notes anywhere on tolerances for this? The stairs that got installed have a rise and run spacing that is about 1/2" to much. I have walked up the stairs and dont feel any unease, so I would think they are just shy of proper spacing (twice the rise plus the run = 26" max.) I guess the contactor that installed them just wasnt hugely careful. Also the steps are not perfectly level. Some of them are 1/4" off across the 28" span of the step. Is this a major problem that should need to be corrected?
- Second question is in regard to reinforcing plates, used to attach the steps to the tank. Some of these plates cover the tank seems and they are not much larger than the steps themselves. Thus they do not exceed past the seems by the required 6" called out in API-653 9.10.3. I was going to recommend that these plates be removed and the plates be replaced with proper size plates. In order to do this, they may have to combine reinforcing plates from two or three steps together. Am I being way to extreme here? Is this requirement on API 653 actually supposed to deal with staircase reinforcing plates or for actual spots where the tank is worn or cracked and needs to be reinforced?
Again, this staircase feels perfectly fine and is not by any means un-usable or uncomfortable to use. So I am wondering if you guys have any experience here. I am going to recommend that any deficiencies be corrected? Am I going to an extreme? Opinions are welcome.
Thanks,
Rob
Thanks,
Rob
