I'm struggeling with the same problem as you xema77.
1) yes indeed ,if you multiplie the tank circumference and wl, you get the liquid weight.
(I assume that because, in API 650 edition 10 ad4,in formula E-23, wa is also computed for the tank circumference)
2) did you have already found an answer on this question?
