API 650 Handbook
  • Thread starter Thread starter -
  • Start date Start date
Guest
I need API-650 handbook.
Can somebody say me, where I can download in PDF.
Thanks.
It can be PURCHASED from Global Engineering Documents, which is the official distributor of API standards. Their web address is . The API codes are not distibuted free of charge. If you find a place to obtain them for free, then it is akin to stealing from API, and can probably expect to hear from their attorneys if you download a "free" copy.
What is the tolerance for vertical, diagonal and lenght dimensions of each plate of a vertical storage tank according to API 650
I know this is very late to respond to this thread, but if you are still interested in plate tolerances I offer the following. A shell plate is typically layed out and cut to plus or minus 1/16 inch on length and width. The diagonal tolerance is normally i/1 inch. Hope this helps.
Steve Braune
Tank Industry Consultants
Correcting my previous post to this thread... the tolerance on the diagonal dimension of a shell plate is 1/4 inch.
Steve Braune
I am very sorry, but I have to correct my previous correction. The diagonal tolerance on a shell plate should have read 1/8", not 1/4".
Steve Braune
