kalluna
- Jun 25, 2009
- 7
Looking for some input or suggestions as to how to handle fall restraint/railing at vertical tanks.
As far as I understand from API 650, one of the conditions that must be met before having a frangile roof is that diameter of roof must be 15.25 m or more in diameter.
Most of our vertical tanks are smaller than that. However we have traditionally built (all) our tanks with a railing only on a portion of the roof edge,as someone way back when thought that would enable the roof/shell joint to be frangible.
Since we are now developing a proper fall restraint policy, I am proposing that we put railing all the way around the top of tanks (smaller than the 15 m dia), with a lower rung placed so one cannot slide off even if you fall down onto tank roof.
Using fall restraint harnesses while on tank (tied off to central painters post) is fine if there are 2 people, but if, (despite policy), one person goes up by themselves and they fall they could be hanging in harness for along time and possibly die (these task are in isolated locations).
For larger tanks which can have frangible roof we'd probably need to use and enforce the fall restraint/harness/2 person rule, and I guess there we would not need railing round full perimeter..
Any comments would be welcome.
Thanks!
Heather
Thanks!
Heather
