My apologies, but I am not familiar with that grade of material. API-653 requires that the repair material comply with API-650. API-650 permits the use of material produced to a recognized national standard, subject to compliance with all of the requirements of API-650, Section 2.2.5. This requires limitations of some elements in the steel, required ratios of yield to tensile strength. In addition, the material must have adequate toughness at the design metal temperature. The design metal temperature is the LOWEST temperature of the material, based on ambient conditions. All of this is well covered in 2.2.9.
Joe Tank
