I am working my way through a cone roof design for a 12' diameter silo rated to 14.9 psi. I am using API 620 as a design basis, although the silo will not be stamped / monogrammed to any standard. The rest of it is designed per ASME Section VIII, but I've been asked to explore a shallow cone roof option instead of a F&D head.
I have a design that I believe passes API 620, but I have also been using FEA as a gut-check on the design. As expected, the region around the top joint is in circumferential compression. I have explored using figure 5-6 detail 'g' and detail 'h-1' among others. The added material to satisfy API 620 cross-sectional area requirements resists the compression nicely. However, there is an area of concentrated high tensile stress directly on the inside of the roof-shell joint. The stress is well above yield. The cause is fairly obvious. It is a bending stress as the joint tries to "flatten" as the cone roof is pushed up and the shell is pulled in. Is this not a concern? API 620 does not appear to address it anywhere. It just assumes the joint is fine if the compression ring is adequate.
Please advise if I am over-thinking this or if this issue is addressed in another portion of 620. I am experienced with ASME and API 650, but not so mush with 620.
