Thanks, API 617 simply states on lubrication and sealing system "Unless otherwise specified, pressurized oil system shall conform to the requirements of API Std. 614, Chapters 1 & 2. API 614 Basic design " The design shall allow for transfer between and shutdown of the main and spare components of the system for maintenance without interrupting the operation of the system or the equipment the system serves". API 614 Pumps and Driver "The oil system include a main oil pump and a standby oil pump. The main and standby pumps shall be identical and suitable for continuous operation". The start-up control of the standby pump shall be actuated by devicexs gthat sense low supply pressure to the equipment or low oil levels in the overhead seal oil tanks. However i cant find neither on the API 617 nor 614 that states that both the main lube oil pump or the standby lube oil pump shall be both designed on auto start-up mode.However, API 614 4th Edition page 96 on accumulators states that "The control pressure shall be maintained above the equipment manufacturers minimum specified, supply pressure at all operating conditions (including transient. What i understand with this clause is that whether the lube oil pump running is a motor or the turbine, accumulator design shall consider both case and that they shall be design both on auto start-up mode. Hoping for your comments...thanks
