API 613 - Post Mechanical Run Test - Casing Leak Test requirements
inspect58
7
After an API 613 Mechanical Run Test (Gear Box), disassembly inspection, and reassembly, does API specify a case tightness test? Most gear box manufacturers do this, however I'm just curious if this is an API 613 requirement. I can find the requirement in API 613.
Thanks.
