API 520/521 Noise Calculation
NG_Engineer
I've got a question about the formula for estimating noise from a relief valve that is in API 521.
Has anyone done empirical testing to verify the accuracy of the estimate? I haven't been able to find anything about verification.
I wanted to use the formula to get a quick estimate of the noise produced by a pipeline blowdown valve. I believe it should at least get me a reasonable result, a blowdown is similar enough to a full open relief valve in this function.
I have heard about a NASA report that was published in 2001 called "A Reduced-Noise Gas Flow Design Guide" on here, and if anyone has a copy of the report and spreadsheet I would love to get a copy of it.
Also, if anyone has suggestions for a better way to estimate noise from a blowdown valve (reduced port ball valve, full port, plug valve, etc..) I would appreciate it!
Thanks.
Yes. Thank you for the response.
I talked to our SME for relief valves and he agreed that the formula should work for an estimate of the noise.
