We have placed the order for Sub-sea API 17D Gate Valves with API Monogram requirement. We are informed by the supplier that Gate Valve will be supplied as per API 6A design with Hydraulic Actuator (as per API 17D). However, this Gate Valve Assembly will not be monogrammed due to mix-up of two different specs (API 6A & API 17D). As per my understanding, at least Gate Valve can be individually monogrammed to API 6A. But, supplier says it is not possible due to Valve assembly with Actuator having 2 different specs.
My questions a)Why can’t individual item monogrammed to their respective spec?
b) Can we use API 6A Gate Valve for Sub-sea application? What is the significant difference between API 6A and API 17D Gate valves in reference to Design, Performance requirement (PR2) & testing’s?
Appreciate your feedback. Thank you.
