compressionmanager
Petroleum
I have recently been involved at my company in the development of crack repair procedures for natural gas pipelines. The code specifically requires a qualified procedure for cracks which sets cracks appart from other weld defects. However the code does not specifically state how to develop the procedure. A common disagreement within my company is that the qualification of the prodecure must start from an actual craked weld. Others believe that while you must have a procedure to remove the crack, the actual crack is not essential to the procedure since the complete removal of the crack can be verified by non-destructive testing such as mag particle, die penetrant or other methods and once the defect is removed it is simply qualifying the procedure to redeposit the weld metal. Has anyone been involved in the development and qualification of a crack repair procedure and if so did the procedure require starting from an actual cracked weld. Another part of this is once the procedure is developed and it is necessary to qualify welders, does the welder qualification process require starting from a cracked weld. Any comments would be appreciated.
