When PT testing a butt weld on 14” (14” O.D.) pipe a toe crack is discovered that is 3 5/8” in length. Under API 1104 can this crack be repaired using a qualified repair procedure?
Under API 1104 what method of inspection must be used to inspect an area of a repair?
After some digging around in the code I think the answers are tucked away in sec. 10.2 & sec.10.3.1 respectively. Can anyone validate this for me?
Cheers,
Jellopool
Cheers,
Jellopool
