Anyone with Resistivity imaging experience?
ckc8008
Geotechnical
Mar 6, 2005
3
Hello.
Does anyone here have any experience with resistivity imaging techniques? particularly in 2D.
We are in a karst area, and I have been thinking about making the $30k investment to add this technique to our business. People always want to know if their site is over a sinkhole; and this procedure may help us to offer another means of investigation (other than soil borings) and of course increasing our business.
By the way, we have clays (PI= 20 to 40) and bedrock at 60' (18m) +/- in this area. No sand at all in our area.
Any insight is greatly appreciated. Thanks in advance.
There is a lot of hocus-pocus involved in both methods. Neither method will reveal the presence or absence of sinkholes, although it might give you supportive information.
I have looked at hundreds of geo reports with GPR, and have only seen 2 or 3 with Electric Resistivity. The GPR does not appear to be accurate at any depth over a few feet. The ER images, when I have been able to view them in color, were much more definitive in showing anomalies that may indicate ravelling, loose soils, or clay layers. I would say that Electric Resistivity is more promising than GPR. On the hundreds of reports I have seen, the GPR report does not even pick out the iron or copper water pipes going into and out of the home. This is in Florida, where the soil is mostly sand, with some areas having clay layers. There is a clay confining layer over the limerock in much of the state.
In no case is either of these methods (or any other method) capable of definitely locating a "sinkhole". They very seldom even find a definite ravelled zone. Both methods are limited in the depth to which they are accurate, with 20 feet as a practical maximum.
The method of SPT borings is the most revealing about subsurface conditions. Most geotech reports use only 2 SPTs, 2 test pits, 5 hand auger borings, and 8 to 12 GPR transects. There should be more borings than just 2 SPTs. I saw one report recently with 3 SPTs, 2 of which found limerock at 27 ft, and the third went 95 in sand with no limerock being found. Most of the houses that we have underpinned can have at least a 20 to 30 foot variation in limerock depths, with 60 foot variations being very common.
I have been told by geotech engrs that the only way to really understand the GPR is to be there reading it as it is moved along the soil surface. But even with that, their anomalies are not too accurate. Many times we have grouted where a GPR report says there are loose soils, but it will take no grout. Other areas on the same lot will take a lot more grout ( 1 or 2 CY). (When you hear about a property taking 100, 200, or 700 (!!??) cubic yards of grout, it has been pumped into the Aquifer in the limerock.)
I can give you the name of a soil engineer here in Florida who has written some papers on ER vs GPR, he would be better able to give you advice. There are different voltage and milliamps and frequency combinations that are probably important.
Janine Pardee PE
Structural/civil and mechanical
Orlando, FL
ckc8008,
I have used a 2D resistivity imaging system many times and have had excellent results, and often excellent correlation with soil borings. I have used ERI in karst investigations, but only limited application. Most of my work has been to identify top of bedrock in sedimentary environments, and also environmental work to investigate contaminant plumes, etc.
Several DOTs are using geophysics to aid in their subsurface investigations (CalTrans for sure). As was stated earlier, these methods should be used in conjunction with borings and test pits, etc., and not soley by themselves. Field truthing and confirmation is required, but geophysics can really help reduce the number of borings required. Also, as they are uninvasive, often times people will allow you on their property whereas they won't allow a drill rig or other equipment.
I have a library of LOTS of excellent journal papers that may be of interest to you, and can also provide some excellent firms that may be able to steer you in the right direction. Please contact me offlist at rockjoint@yahoo.com if you are interested.
--Rockjoint
