To answer several inquiries regarding ModelCheck< I would like to add the following:
I have used ModelCheck for a while and find it useful.
In WF III,
ModelCheck does not automatically change anything, in the case of missing layers, parameters, etc... ModelCheck investigates the part, or assembly, or drawing and suggests the overall 'quality' (red, yellow, or green) of the file vs. your requirements. What constitutes red, yellow, or green status is up to you.
After making changes to the model, you will still need to run
ModelCheck again to confirm that the part status is improved. You can
have ModelCheck update the part 'quality' status automatically upon
regen, file save, or manually.
If the model is missing layers or parameters it will suggest to add them, or delete others that are not on your approved list. When small edges, children of rounds, etc... are found, it allows you to see where these are to correct later.
You have the opportunity of linking the 'quality' of the part with the ability to update file in Interlink, pdmlink, etc.
ModelCheck comes with a configuration program that works outside of Pro-E that pretty-much walks you through the process.
I suggest that you start small, such as checking the format of parameters and layer status, etc.. and work from there.
My major gripe about layers in Pro-E in general and Modelcheck is that features are added to layers manually based on rules, but you can't create/import layers with rules in ModelCheck.
BTW, when you install Mxxx updates to Pro-E, PTC thoughtfully overwrites all of your ModelCheck files! Make sure to create backups.
