bradhuntley
I have an application that requires an AND function that turns on an LED. My thinking is that if I use pins 2 and 3 for the AND inputs (logic false, switches to ground) and put the LED in series with pin 5 connected to power, it should work. There is nothing written in the data sheets as to how to select the current limiting resistor. Is it selected by .7V/desired current?
