Superslinky
Automotive
Hey all, would there be a way to remove a solid from a solid? Any AutoCAD users would know what I'm referring to with the subtract command. What I have is a 2 parts, one needs the negative of the other without actually using it. Is there any way to do this? Keep in mind that these are 2 parts and not an assembly. I need to bring them both together and then remove one from the other so I'm left with the "imprint" of the other one. Let me know if you need more info.
