Any way of making a perforated part less heavy?
atama
Industrial
Jul 31, 2007
30
Hi, I have a 90/80 cm, 2 mm thick plate that has 112 irregular double holes (i.e. 224 holes) in a specific pattern. I made the holes' pattern in the sketch, I think this is the "lightest" way. The file is still very heavy and reacts very slowly. Is there a better way to do the pattern? Would a feature pattern be lighter? Is there a trick I don't know?
A feature / fill pattern may help, but I normally create another config with no holes in it for use in the assembly and only use the config with holes for ref in the drawing.
Woolly
I used the linear sketch pattern in the sketch itself. Where and what is the geometry pattern option?
I missed that you used a sketch pattern. I find feature patterns to be easier to edit.
[cheers]
Please tell me I'm not the only one who read the subject of the post and thought, "Umm, make the holes bigger?"
Sorry...
In SolidWorks 2008, you can create a cosmetic pattern on a planar face. This does not create the geometry, but rather a representation of the geometry. This should be much faster. I would advocate creating 2 configs. Have one config for the actual geometry correct version. In the second config, supress the feature pattern and create a cosmetic pattern. Each config could be used for different purposes, depending on needs (correct weight, performance in assemblies, etc...).
Pete
atama,
Pete and Wooly's advice to use two configurations is about the only effective option. The regeneration time is not so much a function of the size of the part, but its complexity. Even that is not so much a function of the math to generate the geometry, but all the surfaces that are created. Using the Geometry Pattern option, if it works, rarely saves on the regeneration time. Saving a part with all the holes as a parasolid and then importing back into SWX demonstrates this easily. The part is a dumb solid, but due to all the holes is slow to regenerate. This is an area that benefits from a good graphics card.
There really is no work-around except to reduce the part complexity by using a simplified, i.e., no holes or only holes in certain places, configuration.
- - -Updraft
