What are the advantages/disadvantages of a dry pipe system vs an antifreeze system? The existing building I'm working with has 2 seperate unheated combustible concealed spaces on each end of the building one 1300 sf and the other 950 sf. It also has an exterior overhang that will require an additional 4 sprinklers. Is there a size limitation for antifreeze systems? Are there situations where a dry pipe should be used over antifreeze, or vice versa?
