Jan 27, 2010 #1 kee0419 Mechanical Joined Mar 1, 2007 Messages 13 Location US Does ANSYS Workbench have option of mid-plane shell mesh or surface shell mesh similar to COSMSOWorks? If so, what are the steps using GUI?
Jan 29, 2010 #2 bobbywvu Materials Joined Mar 21, 2006 Messages 45 Location US When you use mid-surface and while meshing, select src/trg selection to automatic or manual thin, ANSYS GUI will give you an option between solid and solid shell element. Also try to search about src/trg in ANSYS help for more info. Hope this helps. Upvote 0 Downvote
