Ansys WorkBench Error Message
g1a1
29
I receive the following during solution, "An error occured while starting the Ansys solver module". Does anybody know how to resolve this issue? Thanks
Have you applied any loads? Are the boundary conditions set? What type of analysis? Etc. etc...
See faq569-1083 for details on how to make best use of Eng-Tips.com
All loads, materials and BC have been applied. Its a static structural nonlinear ductile analysis.
It could be an endless number of things. The information you've given is less than adequate and so no definitive answer can be given. Go through each option step-by-step in the WB tree, removing each option (or redefining with a known working condition) until the error message disappears.
Drej: I apologize for the small amount of info. What would information would help you? Does the ansys solver module have to be toggled "on"?
Start from the begining and supply information on everything you've done to create the model. Doing this will probably lead to YOU finding the error anyway.
Drej, Ansys tech. solved my problem. I had to install workbench service pack 11 for running in WinXP OS. Thanks for all your assistance!!
