ANSYS WB nodal averages of surfaces
cvan42
Good Evening, wondering if any of you know how to script the averages of a result across a surface. Normally I'd be hesitant in stress/strain. We're working on simulating an oven and would really like to script average temperatures and fluxes across some surfaces, as min and max don't really help, probing the surface is not very accurate. Any help would be greatly appreciated, Thanks in advance,
Chad
Hello Chad,
I did the same think in Ansys Classical using a short macro written in APDL. It works only for planar surfaces I think.
Code:
!!! preselect elements on surface (nsla $ esln)
!!! predefine local coordinate system at the center of the  surface
!!! Integral will be computed in the active coordinate system
!!! surface integral will be saved to variable SIGNAL
/nopr
/post1
wpcsys,-1,1000
sucr,sensor,cplane,3
supl,sensor
*get,actsys,active,,csys
rsys,actsys
sumap,bfeld,B,y
supl,sensor,bfeld
sueval,signal,bfeld,sum ! compute integral on surface
/go
Alex
