BarryWatson
I'm analysing a structure which has a cylinder and both the rod ends have spherical constraints. Free rotation x,y,z but can react translational loads in x,y,z. These spherical constraints are not grounded and are within the structure itself. When I use a body to body spherical contact the analysis does not run. Further reading tells me this is because solid elements need to be further constrained or the spherical contact surface has can infinetly rotate. However as it is body to body I can't put any global constraints at the contact surface.
Does anyone have any suggestions?
