mjjmecheng
Good morning! Quick question for the gurus out there.
I have been working on an Icepak (v.14, Ansys 2013) simulation for a chassis design. In the design, there is one fan that pulls air from inlets in a computer chassis through a number of channels and exhausts the air out the back of the unit. For the time being, I am only interested in airflow and have turned of any thermal calculations in the model. I have deactivated gravity for the time being as well.
My issue is that I have performed numerous simulations using different gridding techniques and though my results always appear nearly the same, I seem to have one fundamental issue. When I go through and tally up the airflow through the 6 inlet ducts that I have, the sum is ~15% different from what Icepak tells me that my fan operating point is. For example, my exhaust fan's operating point is 31cfm while the sum of my inlets is only 26cfm. Am I misunderstanding Icepaks definition of the fan's operating point? I don't seem to have any leaks in my model.
Air @ 160F. Elevation = sea level. Gravity off. Ambient air pressure = 1atm.
Thank you for the help!
