Ansys Fatigue in Workbench
Stum3
GB
Hi all can anyone help
when doing a fatigue safety factor in Ansys WB 13
it would seem anything above 1x106 cycles doesnt change
the fatigue safey factor.
ie i have just set up the same analysis with 1x109 cycles
and 1x106 cycles and the SF doesnt change it only changes
when you get below 1x106 cycles a little confusing
can anyone help
Stu
This is not really a question about ANSYS. You should read up on fatigue before dong a fatigue analysis. Specific to your question, you should read about endurance limits, then determine if they are applicable to your specific material.
but it is about ansys, the material is carbon steel
and i have found my answer
"In a constant amplitude analysis, if the alternating stress is lower than the lowest alternating stress defined in the S-N curve, the life at that point will be used."
Hence the stresses in my analysis were very low but it does give
confusing results if you dont know the above
Stu
