Ansys Error 1
aldotoscano
Aerospace
Hi!
I'm trying to run a Modal analysis but ANSYS stops with the following error:
PCGLSS0055:2194320 bytes(sizeToBeAllocated 2194304+init_offset 16).
ANSYSMALLOC failed.
Could someone tell me what's going on?
Thanx!
Are you using the subspace method for modal extraction? Do you have to use the PCG solver? Have you tried using the default Block Lanczos (eqslv,) first?
Hi again, Drej asked me for more details about my problem:
I'm using the Block Lanczos (eqslv).
