Jos007
- Jul 16, 2014
- 10
Hi all
please check the following link: as you can see it's a pipe system modeled with shell181 elements subject to internal pressure (only)
i need help about the membrane stress i get at the nozzle intersection
- it should be considered local membrane stress so the allowable stress limit should be 1.5S, is it correct?
- or maybe, since it's a very high geometry discontinuity location, i can consider the allowable stress limit equal to 3S?
i have been increasing the main pipe and the nozzle equivalent tickness to low down the membrane stress
but the solution i'm getting out is not cheap and hard to build
any nice tip would be very appreciated
thanks
thanks
