I'm still working through some of the transmit refinement for our antenna design. I've had a chance to actually see what is being measured by using a Tektronix Spectrum Analyzer. Definitely an eye opener. Now comes another interesting question about our antenna system. If you check my original thread, , I drew up a representation of the receive antenna(similar to a Magnetic Read Head) design. Currently we are using a static 5V DC derived from 24V and a voltage divider, to monitor a break in the wiring. We are blocking the DC from the rest of the receiver section with polarized tantalum caps to reduce issues with specific frequencies becomming unstable. What my question comes down to is this.
Does any one know, or had experience with, the affect of leaving a static DC potential on a large inductor and then bombarded it with a bipolar pulse from another antenna. I've noticed that with the antenna monitoring circuit enabled in the system, I can see a fairly vigorous transition on the supply system when our LCD backlight extinguishes, along with the output of the post processing stage amplifiers. When the monitoring is disabled, I no longer see any transitions in the power supplies, or the post processing during the backlight transitions. Because we work with such low frequencies, and the method to detect the metal is treated as a slower(5-12Hz) sine wave. I'm unsure of a viable way to shunt the current spikes to ground while still enabling the monitoring and detection signals to properly pass. Realistically I'd like some ideas as to what effect the power supplies can be seing from the static poential resting on the antenna when it's being bombarded with a frequency, and if it's possible to filter that response out.
