I am looking for advice and I have obviously come to the right place..
The engine we are going to build is for a Pulling Garden Tractor. I have two roads I can go down, the Small Block or the Big Block Briggs & Stratton Vanguard V-Twin Engine.
Rules include; 38 cubic inch, 4500PRM Governor, single carb, stock position of valves, cam, crank, etc.
My question is;
Go with the Big Block and sleeve it down to get the cubic inches, or go with the small block and run pretty much stock bore/stroke. (the small block has no room for a long stroke crank)
The Big block could be configured one of two ways: 2.83" bore/3.07" stroke, or 2.66"bore/3.41" stroke.
Small block configuration would be 2.97" bore/2.76" stroke.
Given the RPM limit, would I be better off with the long stroke engine? Most conversations about this are in regards to engines running the highest RPM's possible, I just wonder if a 4500RPM limit would sway your answers toward the long stroke and if so, is the longer configuration too much?
Other considerations would be in regards to valve shrouding. I the increased flow potential of the larger bore more important then the old Bore/Stroke argument? At 4500rpm/19 cubic inches (/Cylinder) do I need to be that concerned with that valve shrouding?
My question is;
