Hi, I've got an assembly of a mould. Essentially a bunch of plates with differently shaped inserts in between them, and a million pins and screws.
To save time when I was making the assembly from the individual parts, I used a lot of component patterns, especially with the inserts and pins and screws.
What I am required to do now is make an animation of the assembly, as it moves in the part. I grouped parts together into sub assemblies to make this easier for me, but then I encountered a problem... I couldn't add any of the component patterns to the sub assemblies, or it would delete them. Also, I cannot animate any of the component patterns.
Is there a way I can group these component patterns into the subassy's without having to break them and redo all the mates? We're talking hundreds of individual parts if I have to do that.
One thing I thought of, but am afraid to try before researching a bit, is breaking up all the component patterns and letting solidworks automatically determine mates based on all the positions of the parts. This method seems like it would work, but I could see all sorts of incorrect mates getting made.
If I can't put the component patterns into sub assy's, if I could at least find a way to animate them (using the animation wizard) then I could manage.
Thanks in advance for any assitance, I know you guys can find some way of helping me.
