angular dimensions
swhits
Military
I am trying to have an angular dimension with the leader at the end of the dimension. It will only go to the beginning of the dimension, not the end. Is there a way to do this?
select the dimension so it is highlighted
-- RMB --> Properties
-- Terminator and Symbol
Display -> set to either Origin or Measurement
-- Lines and Coordinate
Projection Line -> set to either Origin or Measurement
OK
-- with the dimension still selected 'grab' the black handle
at the free end (cursor should change) and move it to a
position you want it
Origin = the end that is connected to the first line
selected
dy
