JeanMicheling
I have a spindle running at 3600 rpm with a 550 lbs, 12'' diameter tool, mounted with a pair of 7020 15deg ang. cont. at each end. Two companies did bearing analysis for me. One (bearing manuf.)said there was too much preload, one (spindle repair company) said the opposite. It's a high impact, high vibration application. The actual bearings are light preloaded. I'd like to have some experimental feedback on ang. contact. bearing preload.
Thanks,
Thanks,
